help printing a picture
G
Guest
Guest
Archived from groups: comp.periphs.printers (More info?)
Hello everybody,
I have the following problem. I want to print the same picture on both
sides of a A4 paper in such a way that the two pictures superpose. any
ideas on how to do this ?
On 15 May 2004 02:49:14 -0700, harko@cluj.astral.ro (Sebi) wrote:
>Hello everybody,
Use an option to print centered. they should line up ok.
You would have more control if you use photoshop and a printer that
would print to an edge.
Unless your picture is off center then yes you would definately need a
program that lets you set exactly where u want on the paper.
In message <2cf84663.0405150149.6086025d@posting.google.com>, Sebi
<harko@cluj.astral.ro> writes
>Hello everybody,
Depending what you want to do with it once you've printed it, one
solution might be to print on two separate sheets, then line them up and
laminate.
Timothy Lee http://www.wightproperty.com
tlatwightpropertydotcom
Hi
For them to superimpose wouldn't you have to horizontally flip the picture
in your editor after you have printed one side? I tried it and it works
pretty well if you center the pictures. How accurately your printer feeds
the paper has a bearing on the outcome.
Baz
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.681 / Virus Database: 443 - Release Date: 10/05/2004
