HELP Problems with MAME32 V.93
G
Guest
Guest
Archived from groups: alt.games.mame (More info?)
I am having some issues with some of my games in MAME32.
Games such as Dig Dug, Qix, Rally X, Burgertime, and PacMan fire up and
play fine.
A lot of the games however have very choppy gameplay and poor screen
rates. Tempest, Mappy, Paperboy, Pole Position are extremely bad.
On a somewhat related note Mappy USED to play fine and I had an older
version. Then one day Mappy started acting up. I though updating
would help but apparently it hasn't.
Any help you can provide would be greatly appreciated.
Thanks in advance
Josh
> play fine.
As MAME gets bigger, the performance goes down. Older versions of MAME
(.57 or so) will run most games on a 500 MHz processor. I have .95
installed now and it won't even run Don Den Lover Vol. 1 at full speed
on my Athlon XP 1700. Version .86 runs it just fine.
Remember, the purpose of MAME is accurate emulation/preservation of the
game code. Actually PLAYING the games is just a side effect of that effort.
I suggest you use the oldest version of MAME that will play the games
you want.
HTH, HAND
usenet <reply.in.newsgroup@bitbucket.dave.null.net> wrote in a cheese
induced coma news:Y2c8e.3363$h6.267@tornado.texas.rr.com:
> you want.
> HTH, HAND
Sounds like good advice to me. For further help, pickup an older version
of Mame32 here http://mame.joymonkey.com/mame32/
Bustin' Naughty Folks since 1983
See my custom built upright and cocktail cabinets at:
http://home.columbus.rr.com/supermappy/
Come to chat in #tombstones on preacher.foreverchat.net:6660-6667,7000
MAME: Forever Young!
Very embarrased, hangs head in shame question;
I think that HTH = "hope that helps" but I am unable to work out the
HAND acronym.
Please help.
> HTH, HAND
* Phil Cave wrote in alt.games.mame:
> HAND acronym.
Have A Nice Day
http://www.acronymnfinder.com
David
DeVries' Dilemma:
If you hit two keys on the typewriter, the one you don't want
hits the paper.
>> play fine.
> effort.
> you want.
> HTH, HAND
......and to easily find out the oldest version, take a look at the
second half of 'catver.ini', which can be found at http://www.catver.com/
Thnik about it!
Dead_Dad
