HELP!! Problems with Sapphire Radeon R9 270X DUAL X-BOOST OC 2GB
OldDude123
9
Hi guys,
I have bought new rig about 2 months ago and im encountering very annoying problem ever since.
While i play video my display randomly turn into gray/orange/blue vertical striped but keyboard/sound still available/
I have tried nonvenomous things to head this problem :
1. installed all knows version of AMD relevant drivers
2. used 4 different WIN7 version
3. upgraded my BIOS version to its maxed
4. lowered my base working FREQUENCY to 1MHZ instead of 1.070MHZ
5. Sent the whole rig to company - the claim its working fine
6. Bought new PSU : SeaSonic 600W active PFC
7. i ran fumark3D , prime and video card stress - no errors found
and YET NOTHING HELPED and the games keep getting that stripped display randomly
i got frustrated from the situation ...
Thanks for any input =)
Images:
http://i58.tinypic.com/2554cvl.jpg
http://i61.tinypic.com/1zn1rt4.jpg
you can use speedfan.. it can check the whole system temps simultaneously with charts and graphs if needed.. wonderful software
yup, i tried Antec VP-700P 700W which i borrowed from a friend ... it crashed after 20 mins ..
btw both PSU gives 1.213 VDC under stress to gpu (according to GPU-Z).
what are your cpu temps under load while gaming? and have you overclocked your ram?
41 celcius under the tested load... and nope i haven't OC my RAM
its the gpus fault but i dont find anything worng or suspicious.. the best thing you can do is meddle with the drivers
i am out of ideas
it's sure not SYSTEM RAM issue cuz i got 3 diff RAM sticks and every1 one of tham pass the memTest without errors.
I have checked my PSU with voltmeter... i couldnt see any dropouts...
Are there ways to check Temp sensors ?
