[SOLVED] Help!! psu for rx 5600 xt
Jul 30, 2020
One cuestion...
Is EVGA 430w 80 plus bronze okay for an rx 5600 xt?
Another Other PC components:
-Mother Asrock b150m-hds
-hdd 1tb Sata 3
-Ram Corsair 4gb x 2 ddr4
-cpu intel g4560 3.5ghz
-gpu 1050 gtx oc 2gb
Thanks!!!!
uuuhhhh, I can't find a evga 430w bronze. Did you mean the 430w w1 80+ white?
Yeah, it'll power it, but you're going to have a miserable time with only a 2 core 4 thread chip, even a i5 will have problems. Also, you'll want some airflow to the psu, the 430w1 has some degradation at high heat/load.
It'll work, but personally, I wouldn't spend $250 on a gpu and pair it with a $30 psu.
