Help, Random Folders in my C Drive
Krenrai
40
Hi,
I dont know if this is the right place to put this, but i was wondering if you could help.
Recently i've noticed a increase in teh amount of random folders in my C drive.
For example when i open it I am overwhelmed by folders with names such as "f8gdhjf8a8304s" When i open them up inside there is a load of sub folders going from the name "1025"to "3082"
Inside those is a word document which has something to do with a microsoft website which im not allowed to enter.
Is it okay for me to delete these folders? at the moment i have 14 of them.
Thanks
hedwar2011
1,485
98
Some of them may be in reference to a Windows Update, etc. but not likely.
I would recommend running a malware scanner such as MalwareBytes Anti-Malware or Super Anti-Spyware.
hedwar2011
1,485
98
Forgot about those pesky things :ouch: ....and yes running CCleaner will get rid of them.
Krenrai
40
I ran CCleaner, and it hasnt gotten rid of them, is there any setting within CCleaner that i should change?
Krenrai
40
Nope... unfortunately i have Norton360..... Does the job i guess.
But i dont think they are a virus, because whenever i open them, they have something to do with microsoft, for example a load of headers and logos.
Krenrai
40
I just found a setup application in a folder, i ran it and it said it was published by microsoft.
It says;
"Software update KB2468871v2 Installation Wizard" and appears to be from Microsoft.
Hi :)
If they are update folders from MS ...just delete them all...
All the best Brett :)
bookwormsy
136
4
AVG? Avast? Aviria?
Hi :)
Lol that's them... in the Virus removing business we call them the 3 "A`s" ... and that's NOT out of respect lol...
I really shouldn't moan about them as they make me a LOT of money ...
bookwormsy
136
4
What would you recommend then? Right now I use Microsoft Security Essentials.
@OP Glad to see it worked, sorry for thread jacking :D
Hi :)
BEST PAID = Norton Internet Security 2013
BEST FREE = MSE (nowhere near as good as Norton though)
chocostain
178
Most of these are updates. If the scan turns out clean, you can just simply delete them if your system allows you to do so.
Bit Defender is also a good anti-virus.
Scott_D_Bowen
837
38
They're just the hashes of various Windows Updates that get downloaded to the drive with the most available free space at the time.
- As Brett said above, just delete them they are not viruses.
The folder names should only contain the characters 0-9 and A-F (in lowercase) though, I assume you just mashed the keyb to type the above.
Ketan Barshikar
Hi Krenrai,
I am also facing similar issue.
Can you please elaborate what was the exact solution that worked for you?
Cheers,
Ketan
Scott_D_Bowen
837
38
He deleted the folders with the names containing 0-9 and A-F characters.
