Greetings everyone! I have just finished my very 1st PC Build.
My Build: http://pcpartpicker.com/p/9byhRB
My rear case fan is not working! The front and CPU cooler are however. Please note that I have unscrewed the fan and removed it because I needed the extra space to attach the CPU Pins to my motherboard. (Gigabyte GA-Z97X-SLI)
Since plugging in the CPU pin, I reinstalled the fan, screwed it in, and connected to SYS FAN1. Is it plugged to the wrong port?
(YOU MAY ALSO WANT TO CONSIDER THE SELECTED ANSWER ON THIS POST! http://www.tomshardware.com/answers/id-1784581/rear-case-fan-spinning.html )
Thanks!
Thanks!
