Help regarding PSU
Ammar Syed
4
Will my 300W liteon ps-5301-08ha PSU run an asus rog rx 560 4gb oc edition gpu? Total drawn power is 75W. My mobo is msi 2a9c version 1.1 with an i3 1st gen 550, 320 gb hdd with 8 gbs of ram. Please suggest better psus if you think this isn't up-to par.
I think that Liteon unit was in some HP Compaq unit?
It's a 19A/12V rail unit (228W)
73W TDP on the CPU, 75W max on the GPU + other components.
Nearer 200W max draw on a 228W PSU that's probably 6-7 years old at this point? I'd say no.
While their very much 'budget' / entry-level units, the EVGA BT450 or Antec VP450 are both in the $30 range and should be more than adequate.
https://pcpartpicker.com/product/GQX2FT/evga-bt-450w-80-bronze-certified-atx-power-supply-100-bt-0450-k1
https://pcpartpicker.com/product/MnR48d/antec-power-supply-vp450
That being said, for only $10 more you could have the SeaSonic S12II 520W which is a great quality unit, albeit on a dated platform...
https://pcpartpicker.com/product/fZyFf7/seasonic-power-supply-s12ii520bronze
