Hi, so I'm upgrading my XPS 9000 (435T)
(Specs http://www.pcworld.com/product/59659/studio-xps-9000-midsize-tower-desktop-customizable.html) To an MSI N760 (http://www.newegg.com/Product/Product.aspx?Item=N82E16814127744) and before I go ahead and buy it, I want to make sure everything will fit and run correctly. It's 9.5 inches long (Exactly the cut off of how much space I have, 4.4 inches tall and 1.5 inches wide. It's also a dual-slot GPU.) (Pic of my MOBO
http://imgur.com/ObXL8jQ)
I know my stock PSU is only 475W and that I'm going to need to upgrade it. Currently I'd had my eyes set on the (http://www.newegg.com/Product/Product.aspx?Item=N82E16817171094 Cool master V750) I measured my current PSU and that one seems to be a bit smaller than it so I'm pretty sure it should be fine.
and also 8GB of 1600 HyperX Ram
Sorry, I know it's nooby...but do you think this should all fit/work? THANKS!!!
