Help required urgently for pc build
Onlyoneaamir
Commendable
Oct 4, 2016
7
Hi
I am building a mid budget pc
I already have h61 motherboard
I am thinking to buy i5 3570, rx 460 gpu and 10gb ram
Is this build sufficient for games like Assassin's Creed , GTA.
Or should i go for a i5 6500, 8gb ram and gtx 750ti
Is there any major difference in gaming
I also use pc for android app development. Will new gen i5 benefit me or should i go with i5 3570
An i5 3570 & an rx460 will perform better for gaming than an i5 6500 & a 750ti mate.
That is plain & simple.
What about an i3 6100 & an RX 460 ?? - is that doable.
It depends what the cheapest option is for you
Id imagine just upgrading on your current h61 board would be cheapest??
Yeah i know that
Going with i5 3570 would save me 4000 rupees
Also I'm on a tight budget 🙁
is 450w sufficient?
