Hey guys!
After some research, thinking, and reading through dozens of threads here on the forum, I still came to the conclusion that I need your advice for my new pc build.
So here’s my dilemma:
Athlon X4 860K + ASUS A88XM-A = 150 USD
FX6300 + Gigabyte 970A-UD3P = 190 USD
I5 4460 + ASUS H81M-K = 260 USD
I would like to pair one of these up with a Gigabyte GeForce GTX 960, N960G1 (235 USD) or with an R9 285, 8gigs of ram, a 750W PSU with 80+ bronze certificate ( right now 60 USD). Witch one would you guys choose? Would the i5 be worth it, even paired with a really low budget MB (I just can’t afford to spend more on the CPU+MB combo)? Would it make a difference? There’s a 100dollar gap between the cheapest and the more expensive combo here. That’s the most I can spend. Or maybe should I go with the Athlon and spend that 100 bucks on a better GPU (bearing in mind the R9 300 series release and probable price cuts of the 200 series, and that DX12 will further diminish CPU bottlenecks)? I could go with the FX and a cheaper MB but I understand that if I do so, the CPU won’t perform to well. I don’t think I will be able to upgrade soon, that’s why I didn’t chose an i3 option. All the prices listed are from my area.
So, I’m a little bit confused. My goal here is to have decent gaming fun at 900p and possibly later at 1080p, and to build a pc that could last a few years. Even if a combo option costs more a little bit (like stated above, max 100 usd) I would gladly pay that price if that way my pc will “last longer” for a year or two.
Sorry for the long post, I would be really grateful if you guys could help me with some tips.
