HELP! Right or wrong CPU Cooler on AM4 Mobo
hq786
20
Asus Prime B350 Plus Motherboard.
AMD Ryzen 3 1200 CPU
Will Cooler Master Hyper 103 fit into the mobo?
If not
then would Be Quiet - Pure Rock Slim 35.1 CFM CPU Cooler fit?
hq786
20
Would it work as it is or need a special mount that i would have to contact the manufacturer at? I just want a compatible cpu cooler under £25 hat i can buy and install no issues no waiting around
hq786
20
1 question, I have 2 sticks of 4gb Crucial CT2K4G4DFS8213 sticks (8gb total), when I put them into the Ram slots, they don’t seem to securely sit in properly. Also the bottom of the RAM has a curved design so it isn’t completely straight, whether that matters?
Also, there are 4 slots on the mobo,
A1
A2
B1
B2
Manual displays 2 sticks using A2 and B2 only. oh
Would I do the same?
Ram sticks are Single rank. whatever that means
Similar threads
