Okay. I am attempting to run dual monitors, off a desktop. I have both monitors plugged into a vga splitter. Both monitors show windows. The problem is, they are mirrored. So my second monitor shows what is on the main monitor. How do I fix this?
Hit the Windows Key + P, change it from duplicate to extended either by hitting Win+P, arrow keys, or clicking.
If that doesn't work right click on the desktop and click Screen Resolution, and under multiple displays change that setting to "Extend these displays"
I had completely missed the VGA splitter thing, Thanks fa324.
fa324 is correct if you are using a splitter you will get the same image on both displays no matter what. The monitors need to be connected to separate outputs.
