Hi!
So first my specs:
Motherboard: ASRock Steel Legend B450M with bios 4.3
CPU: AMD Ryzen 5 5600
RAM: 2x 8GB 3600Mhz G.Skill
GPU: NVIDIA RTX 3070 ti
PSU: RM650x Corsair, 2 year old
Windows 10 64bit
So i always thought and i actually remember reading it somewhere that ryzen cpus have auto OC, meaning just getting the advertised max clock speed about 4.4 Ghz when playing games etc.. So after i bought it i've looked up on task manager, i see someting about 4.3 Ghz and i think "ok it works". And so 2 years later i see i was wrong.
Now in my BIOS i had the option CPPC enabled. Which i heard its actually not that good for most games etc. i wanted to test it and after i disabled it i noticed my CPU is running at stock clock speeds even in games. So it was only running higher because of this option which actually should not be right?
I have the PBO set enabled in my bios which is for the OC for CPU if im not mistaken right? But this somehow doesn't work because my CPU is still running at clock speeds. What can i do to OC my CPU? Do i really have to set everything manual?
I thought using PBO will do it kinda automatically but it won't work in my bios? is it bugged? I have not the newest version of my bios but i didn't want to update coz its only agesa and i dont want to risk my performance (but im still thinking about it, it i need it for PBO). OR do i have to install Ryzen Master and use PBO there?
I have newest drivers and everything.
Using CPPC in this situation gives me more performance based on Escape from tarkov, probably coz without it cpu running at clock speed, i wanna change it. Have decent cooler, even with this CPPC was running hottest at like 58 C
If needed i can show photos of my bios settings etc. I hope somebody can help. Thanks in advance.
So first my specs:
Windows 10 64bit
