Hey guys, this is my first post and I know there are some similar threads that already exist, but I haven't had any luck with the solutions yet.
So I'm building a computer with these specs:
Ryzen 7 1800x
MSI x370 SLI plus
2x4GB Corsair Vengeance LPX 3000mhz RAM
Corsair H105 Liquid Cooler
Corsair TX650M PSU
Gigabyte GTX 1080 windforce edition
So I built the system (minus the gpu) and tried to turn it on, and I got nothing. No lights, fans, nothing. I checked all my connections and they were good. Tried to turn it on, nothing again. I performed a PSU test with a paper clip and it worked, I put the PSU in another computer and it worked. Tried booting again in the new PC with a different outlet, nothing. Tested the new system with a new power supply, nothing. Keep in mind I'm trying each time with the button on my case and by shorting the pins. So I eventually got sick of doing this and returned the motherboard (direct swap) b/c one of the threads here said to do that. I tried with the new mobo and there was nothing again. Then I returned the CPU and RAM (direct swap) and it's the same story, no lights, no fans, nothing happens at all. This is my first expensive build and it's kind of getting to me, any help is appreciated. Thanks!
Edit: Also cleared CMOS.
Ryzen 7 1800x
MSI x370 SLI plus
Corsair TX650M PSU
