Archived from groups: alt.comp.periphs.scanner (More info?)
Hello,
I've been using a scanner Microtek Phanton 4800 for 5 years now under
Win98/SE/Me.
I'm connecting it to my PC with a SCSI/USB1 adaptor from Entrega and it has
been working fine. (Connecting it via USB allows me to hot swap the scanner
from from one PC to
another when needed....)
I'v' 3 problems now moving to Win XP Pro SP2:
-I need a driver for XP allowing connection via USB1
-I replcaced the neon light but the power(yellow) and ready(green)
LED/lights are still blinking for long time before stabilizing lighted,
which probably mean the condensator/capacity/starter is bad ... I would like
to change it, but I can't find the place where it is located !!! ?? So, ....
-I would appreciate to get an electronic copy of the ref/tech manual for
this scanner ???
If somebody can help, thanks in advance
Regards
Castor , e-quinqua
enlever le ~ pour utiliser l'adresse email
Hello,
Win98/SE/Me.
from from one PC to
this scanner ???
Regards
Castor , e-quinqua
