Help scary pop ups
Arterus
53
I just got these when I tried to view a web page. Please someone help!!!!!
Here was the first pop up I got
Here is the second
3rd
After the third I was able to close it.
Any Ideas?????????????
Kaspersky missed it. There are certain ways to scan for malware, that are better than others. Follow the malware guide in my signature.
Ah.. henydiah, you need to stop handing out bad adivce, nothing in the bios will give you a virus alert and using firefox will not do anything for this guy as the system is already infected.
Go to the sticky post in this forum, there is a removing malware guide. Should have been the first place to check before posting. You have a very common fake anti-virus malware.
Thanks for all the advice, I went ahead and got Kaspersky Internet Security and did a full scan and it found nothing. So I guess my pc is fine. I guess thats just a false pop up. B/c my pc only has 1 hardrive, no floppy drive. But the pop up shows 2 hardrives, and 1 floppy.
Okay after reading the guide I decided to run Kaspersky in safe mode with the connection like it said. When running Kaspersky in safe mode it found the threats and fixed them. Also just to be sure that Kaspersky found them all, I installed malewarebytes and did the scan in safe mode and it said zero threats found. So Kaspersky got them all once I ran them in safe mode b/c in normal it found none. Thanks so much for all the help, now I can be stress free.
