Question Help Screw won't unscrew on HP Omen 15 ce019dx
Jan 9, 2020
37
One Screw refuses to unscrew, screwdriver worked fine for all the rest, but i swear that one won't budge, unknown if scripped, if it scripped, then i guess later on when i do purchase ram upgrade or m.2 upgrade for it, Then best for a Local PC shop to do that upgrade, as they probably have means of getting it open safely, and doing those upgrades properly
Jan 9, 2020
37
The Left Most middle screw on the HP Omen 15_ce019dx, all others came out fine, except that one. Not sure if it was star head or not, looked to be Philips to me, as was using a small Philips screw driver that i got with one of my External enclosures for small screws
Will try to find my needle nose pilers, and see if that works.
Wanted to open it for a simple reason of dust clean out for now, then later on ram upgrade to 16gbs, then m.2 upgrade and thats it in the future
Ordering a PC toolkit for birthday tomorrow, hopefully that will be of some help as well
delaro
Splendid
Ambassador
For a Phillips If it's stripped then try a small flathead, press down hard with your thumb and use a pair of pliers to turn the screwdriver. You will need a bit that has been heat-treated or the edge will bend quite easily.
Jan 9, 2020
37
Ok first gotta find my pilers, and small flathead lol, after RL move can't find anything hardly lol. Might just wait til the toolkit arrives, and go from there
Jan 9, 2020
37
Yeah pain in the rear to find anything at this rate LOL, most critcal stuff i unpacked first lol, and rest of the stuff still packed, and who knows which box or where lol.
delaro
Splendid
Ambassador
I kind have to wait till it warms up 😔 My evil scientist lair will be in the back of my garage which is unfinsihed and unheated and all extra cash got diverted into the 8KW or solar panels we are having installed over the next few days.
