HELP! Second monitor is showing no signal
Delyriouz111
Commendable
Aug 19, 2016
4
Ok so i just got a new computer about a week or so ago. I try to plug in my monitor to my VGA and my hdmi por nand it will not work, it shows no siginal. So i have one of the 24 and one prong adapters for hdmi and that worked. So then i try to plug in my second monitor and its not working. I plug it into the hdmi (non adapted one) and says no siginal, Ditto with the VGA. I unplug my monitor thats in the adapter and plug it into the other hdmi slot (non adapted one) and it doesnt work! Please help! I am a streamer so this is really annoying! I need my second monitor!!!
No no no. I am using a hdmi cable on the hdmi port, and it is not working. So i was thinking hey maybe its just that port, So i brought in my monitor thats VGA and tried that on the VGA port and it is not workign either,
I tried to use only the hdmi and not the adapter and it didnt work. This is the adapter that i use, and its what is working: https://www.google.com/aclk?sa=l&ai=DChcSEwiGt63A6c7OAhWHJIEKHfZ0C1MYABAF&sig=AOD64_3HWEWbXmuD3HUrpWREQLK1HIZ4eA&ctype=5&q=&ved=0ahUKEwigpqnA6c7OAhUFPiYKHfTvB9MQwg8IKA&adurl=
