Last month I built a new PC to use for gaming and also to hook up in my family room to use as DVR. Here are the specs:
i7 920
AsRock Extreme mobo
6Gb OZC DDR3
Sapphire HD 5870
twin WD Caviar Black 640Gb HDDs
Windows 7 64bit
I want to add a dual tuner card to use with Dish Network in the Chicagoland area. I want to use the PC as the DVR. I also am not sure what other options I have to pick up content through the internet to use in Media Center. I am also not sure if I need additional software or if I can run everything through Media Center. Suggestions for a dual tuner card would be greatly appreciated.
You may notice I did not list a tv. I am currently shopping for that as well. It has to be right around 46" due to the entertainment center. I will use it for this PC to watch tv and movies and for gaming on the PC. I may also use it for my Xbox 360 or PS3. Any suggestions for the tv? I was looking a the Samgung and Sony sets. Do I need 60 Hz? 120 Hz? 240 Hz? LED?
Finally I am also getting a new receiver for the system but am concerned about input lag. I currently game on the Xbox 360 and PS3 on an HP md5880n 1080p DLP set with no problems. Video is running directly from source to tv (not through the receiver). Any suggestions?
Thanks for your help!
i7 920
AsRock Extreme mobo
6Gb OZC DDR3
Sapphire HD 5870
Windows 7 64bit
