Hi,
I currently own an HP Pavilion 500-141ea, which comes with an AMD A8-6500 APU, and HD8450 to run in Dual Garphics. However, I found that I wanted an increased boost in gaming performance, so after doing some research, I purchased an Asus HD6670 1GB GDDR5, which is suppost to perform will with the AMD A8-6500 (it is the highest graphics card that APU will do dual graphics with). Once installing it (merely taking out the old graphics card and inserting the new one), I am not able to access the BIOS to configure dual graphics as my computer makes 6 beeps and flashes, and then goes straight to the Windows 8 login screen. HP are unhelpful because changing the graphics card voided my warranty. What is the solution to setting up dual graphics? I am happy to answer any more questions you may have.
Many Thanks,
Many Thanks,
