• Hey there, Guest! Share your idea for a new trophy in the forums and win bragging rights and a $100 Amazon gift card! Check out the New Community Trophy Contest here!
  • Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
Help setting up my Graphic Card
michael06
136
Hello yall I just built me a New Gaming Computer on Sat & im having trouble with some things here is the spec of my PC
Gigabyte 970A-UD3 Socket AM3+ 970 atx amd motherboard
Amd Phenom II X4 840 Quad-core Processor 3.2Ghz Overclock it to 3.8ghz
Corsair
Hydro Series H70 High Performance Water CPU Cooler
Patriot G Series Sector 5 4Gb DDR3-1600mhz
Timing 8-9-8-24
EVGA Nvidia GeForce GTX 560 Superclocked 1GB GDDR5 Graphic Card
Hitachi 500Gb 7200rpm 16MB Cache Sata 3.0Gb/s 3.5 Internal
hard drive
Ocz ModXStream Pro 700Watt ATX Power Supply
Antec Gaming Case W/ Blue Neon Lights
LG 22x Dvd Burner+Dual Layer
I got everything set up & im looking at the amd overdrive & I look into the GPu Status & my graphic card is not operating on amd overdrive? I open up a different program & my graphic card is showing it working & the clock setting is at 0mhz & Shader Clock 0mhz I need help setting it up & try to go into bios to find the setting of it but cant find it no where!! Also on my motherboard my usb keyboard keeps shutting off & on & I go to look on Amd Overdrive the Diagram & my PCIe is not showing also my other usb is not showing on the diagram!! Can someone help me out I would post pic but i dont see how to attach them or even try to show yall what problems im having!!
michael06
136
oh ya ok thank you for letting me know that nvidia wont work for amd overdrive But i went to that link & that not the problem that im having trouble with!! Do you know the Diagram on the Amd overdrive? my Pcie card is not showing there & my other usb plug in... on window 7 gadgets I have a Gpu Meter it showing my Gpu clock is 0mhz
also Shader clock 0mhz also how do I change the setting?
michael06
136
Im pretty sure I do it showing that it is working but the clock setting are at 0mhz even the shader clock 0mhz!! do you know the diagram on amd overdrive it shows the pcie not there & my other usb stuff not showing my keyboard keeys turning off & on idk what to do!! I have it graphic setup on Peg if you know what that is?
michael06
136
Oh ya Damn well I have used that program before it showing the PCi-e is 1.1x16 my graphic card is a 2.0 dont know why its showing 1.1x16??? the GPu clock speed is at 100mhz memory clock 1026 & the Shader clock is 135mhz... Im on a different program called CPU-Z & im on the graphic its shows on default Clocks
Core 50mhz
Shaders 101mhz
Memory 135mhz
michael06
136
Is the Graphic Card suppose to Run at what clocks they are when you first start the computer or when you are testing it for benchmark? cause when I test it the clocks speeds jumps where its suppose to be at it shows that it working & the Temp is like 64 does that mean its working? or are you suppose to set up the clock speed of the graphic card the way it suppose to be?
brianmz
191
Your card is working, those are the idle clocks, they go up, with 2d usage and 3d usage.
When you are under full load, like gaming, your clocks should be:
Core Clock: 850MHz
Shader Clock: 1700MHz
Memory Clock: 2052mhz
For your card at stock settings
And there is also a midle ground(2d) when you are watching vids, surfing the web and what not.
michael06
136
ya ok it seems to be working cause i been playing alot of games! On the amd overdrive the diagram you know its showing that the pci-e not showing & my usb ports keep turning off my keyboards & mouse & stuff why is that? do I have to update bios or something update the drivers?
michael06
136
I got this gadget for window 7 its a Gpu meter its showing that my Gpu clock is 0mhz
Shader Clock 0mhz also I dont know if i have to change the settings in the bios or not? my computer is acting weird here & there someone just told me to update my graphic driver card i Did then i restarted my computer I had my computer overclock at 3.8ghz & when I restarted everything in the bios restarted itself idk whats going on?
brianmz
191
That's odd, try updating your motherboard's bios, and for monitoring your GPU download MSI afterburner or EVGA precision.
michael06
136
Ya so Far updated bios I think I went to my motherboard website downloaded this gigabyte driveragent scan reults came back saying
Display adapters
nvidia geforce Gtx 560 old
IDe ata/atapi controllers
standard dual channel pci ide controller old
Disconnected Devices
Generic PnP Monitor Old
Hid- Compliant Mouse Old
Usb Input Device Old
I dont know why all this says old? everything else is check green meaning that the driver or something is good!! what can I do?
