D domdott May 30, 2018 4 0 10 May 30, 2018 #1 Hello, Im looking for some help on how I would setup Cat5e voice and data. The Cat5e cables are already all hooked up throughout my house and are cutoff to be connected to something. Any tips on what I connect it to?
Solution ko888 May 30, 2018 The ends of each of the Cat5e cables at the central location should be connected to a Cat5e Patch Panel. Example: https://www.firefold.com/cat5e-patch-panel
richiestang_78 Glorious Mar 3, 2015 5,965 687 46,890 May 30, 2018 #2 Usually with a wired house, all the cables will meet in a utility room meant for the network hardware, the router and modem. Upvote 0 Downvote
ko888 Titan Feb 18, 2009 16,706 42 84,990 May 30, 2018 Solution #3 The ends of each of the Cat5e cables at the central location should be connected to a Cat5e Patch Panel. Example: https://www.firefold.com/cat5e-patch-panel Upvote 0 Downvote Solution
