A bit confused setting up additional usb connections with my motherboard. The connectors for the usb port are separate (not 1 solid plug) so I'm not exactly sure which connect to which pins.
The motherboard has the pins labelled:
12345
6789
1- USB+5v
2- USB P6-
3- USB P6+
4- GND
5- NC
6- USB+5v
7- USB P5-
8- USB P5+
9- GND
The connectors I have are labelled DATA+1, DATA+2, DATA-1, DATA-2, VCC 1, VCC 2, GND 1, GND 2 and SHIELD.
So obviously GND 1 goes to 4, GND 2 goes to 9 and SHIELD goes to 5 but I have no idea what goes where otherwise. Anyone have a clue? Thanks 😀
12345
6789
1- USB+5v
2- USB P6-
3- USB P6+
4- GND
5- NC
6- USB+5v
7- USB P5-
8- USB P5+
9- GND
