help shareing printer on lan
comptech2
i need help shreing a lexmark x5250 all in one printer ive tried the instrucions when it says right click and select share but there is no share button any one have any ideals thanks for helping
I'm guessing you have not enabled the "File and Printer Sharing for Microsoft" object located under Local Area Network Connection Properties (same location you go to set a static IP etc...).
What OS are you using?
