Question Help: Slot Question
Jan 10, 2020
6
Hello , I'm new to the website! Came here today i have a question regarding i want to upgrade my graphic card currently i have HD Graphics 2500 i want to replace it with dedicated , and i want to make sure if This Card will fit in the slots. Please Help me! Thank you for your support.
Graphic Card info :
( Im QUessing i have PCIe 8x or x16 ) as the card slot?
MSI Gaming GeForce GT 710 2GB GDRR3 64-bit HDCP Support DirectX 12 OpenGL 4.5 Single Fan Low Profile Graphics Card (GT 710 2GD3 LP)
Link to The Card: https://www.amazon.com/gp/product/B01DOFD0G8/ref=ox_sc_act_title_2?smid=A2L77EE7U53NWQ&psc=1
My MotherBoard Picture( Link Listed):
https://ibb.co/RjZpzL9
hang-the-9
That 710 card is old and slow, if you are looking for an upgrade to play games, that is not it. A GT 710 may be worth buying used at $20 to use for basic video outputs. Spend a bit more on a newer or faster card or just stick with your onboard video. 1030 is about $80, a used GT 730 with GDDR5 RAM is also much better than the 710.
Reactions: GregUS91
Jan 10, 2020
6
Yeah i may actually go with the 730 , will this one fit my PCI Slot??? I just want to confirm with this card
https://www.amazon.com/MSI-GeForce-OC-Profile-N730K-2GD5LP/dp/B00R2M10SU/ref=sr_1_1?keywords=gt+730+ddr5&qid=1578677845&sr=8-1&th=1
hang-the-9
I would not buy a 730 new, they should be about $30, maybe 40 tops used, just make sure you see it running first. For a new card, the 1030 low profile is the one to get. Just make sure your power supply is over 250 watts and that the BIOS is the latest for the system.
