Question Help!!! Something very strange with my cpu
Nov 15, 2019
After a window 10 update i have a serious problem with my CPU.
When i boot my PC CPU temperature go like 80 degrees even before booting is complete.
Fan speeds up but with no effect. After 30 seconds PC shutdown. I cannot find a logical reason for this because in the breef time i have before shutdown, task manager says CPU load is 5-10% at maximum. I have tried to unplug the power cable for like 30 min with no results. I have deasent machine.
CPU - rysen 7 1700x
GPU - GTX 1060 6gb
power supply - EVGA 700b
motherboard - GB AB350 gaming 3
RAM - G.skill rapjaw 2x8gb
Thanks in advance for the help
Nov 15, 2019
Ty for the fast reply
Cooler is ok everything is in place. Even when the temperature rises it increases RPM to maximum. I forget to mention it i Cooler Master master liquid lite 120mm. I cannot feel hot air coming from it, even when it shows 80 degrees CPU temperature witch i think is even more strange.
Oct 13, 2019
27
JOE MAMAAAAAAAAAAAAAAAAAAAAAAA
no, but srsly, I have had similar issues earlier with my pc just days after I built it. Don't remember what I did to fix it tho, but I can tell you one thing, the solution is probably BIOS related, so go into BIOS settings, there should be a button there where you can reset the settings to default. That might just help.
Thread starter Similar threads Forum Replies Date
D CPUs 6
Rodrigodrt CPUs 3
