So I had recently built my own computer
I want to put it up to 3.0 Ghz
MOBO: Gigabyte P35- S3g
Chip: Q6600 2.4 G0 stepping
RAM: 2GB Kingston PC6400 800 mhz
RAM TIMMINGS: Right now 6-6-6-18
COOLER: Cooler master sphere (its power is attached to the PWR1 slot, it does not fit into the CPU power slot!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!)
PCI: NVIDIA Geforce 7300 GS
MULTIPLIER: 9x
FSB: 266
Voltage : Auto
RAM timings: default
PCI express: 100mhz
I had tried to increase it to 3.0 ghz 333x9, but the temperatures according to the coretemp application says it is in the low 40's during idle
Prime95 was stable for one hour when i stopped it. (The heat went somtimes to the high 60's)
OCCT within 2-4 minutes it says the CPU IS TOO HOT
The voltage was set to 1.2875 V for the CPU during this period.
I did not touch the RAM timings, so what should i do
According to cpu-id it is set to 2:3 ratio.
PS
what is the????????????????????
FSB overvoltage???????
System Memory Multiplier (SPD)???????
Memory Frequency (mhz)???????
DDR2 overvoltage??????????
(G)MCH overvoltage control???????????????
SHOULD I TOUCH ANY OF THIS
please i need help with this
thank you
reply to bluejamesbond@gmail.com or just post a reply.
MULTIPLIER: 9x
FSB: 266
Voltage : Auto
PCI express: 100mhz
PS
thank you
