[HELP] Storage issue mouse freezing
syntaxlive
Commendable
Mar 25, 2016
Recently my computer has been struggling such as getting 40 fps on WoW and 30 on CSGO
so I further investigated to see if it was a hardware issue. So I restarted booting up windows and this occurred 2minutes later. I later figured out I restarted during an update. Then later I checked after the scan and repair same problem happened then black screen. (No malware or any of the sort).
https://www.youtube.com/watch?v=Dg7zOC6wBdA
I believe it is a hard drive issue after doing a scan and repair.
CPU: I5 4590
GPU: GTX 760
HDD: Western Digital Green 1TB (2009)
SSD: Silicon Power 200gb
OS: Windows 10
MOBO: Asrock h97 Anniversary
PSU: CX600M
Thanks to anyone who replys!
Seagate makes a bootable Seatools for DOS that you can use to check your SSD for failure. Or you can try their Windows version if you can stay running long enough to use it. Run the SMART check, then all 3 self tests, starting with the 2 short ones, then go to the long one. If any failures are shown then the drive is going bad.
