Question HELP!!! Strange lighting issue causing a flicker effect
Aug 21, 2021
21
You don't provide much info. Does it happen on other games too or just Warzone ? If it happens only with Warzone probably there is something wrong with the textures. Remove your Gpu drivers with DDU and reinstall the latest ones from the manufacturer website. Remove Warzone, including BattleNet, reinstall both of them and let it finish installing the ingame shaders and see if the problem is solved.
