HELP stuck in APTIO
kamotetop
Commendable
Dec 15, 2016
lf0RO
http://m.imgur.com/a/lf0RO
I am having a hard time doing this on mobile.
I hope somebody could help me.
Try the following and see if it resolves the problem.
1. In the Aptio Setup Utility, select the "boot" menu and then select "Launch CSM" and change it to "enable".
2. Next select the "Security" menu and then select "secure Boot Control" and change to "disable".
3. Now select "Save & Exit" and press "yes".
4. Once you have done this, hold down the "power" button until the laptop turns off completely.
5. Now you want to power it back on and continually press the "F9" button for about ten seconds or until you are taken to the "Windows Recovery Menu".
6. In here select "Advanced Start Up" and then, once the recovery menu appears, select "Advance Options".
7. Choose "System Restore" and select a date prior to when the problem started...
The computer should now go through the restore process and then start normally for you.
Latest posts
