Hi everyone! I built my first ever pc in september. I was having a seamless experience until now but recently the following issue arose and has been really annoying to deal with: Whenever I try to switch tabs on my pc, the following happens: it just freezes for a few seconds and i cant click anything. Everything unfreezes after like 10 seconds every time. This also happens whenever i click the windows button or anything on my taskbar like the search feature. It's only started doing this recently. Any help would be appreciated ! Here is a video illustrating the matter:
View: https://imgur.com/NF1EWZn
. Many thanks in advance !!
For the record : My CPU usage is typically 6%, my memory is at 40% and disk at 1%. Almost all of the memory usage is from google running 40+ instances but i have a LOT of extensions and usually a solid amount of tabs open. A virus check had no result except flagging a hotkey resolution changer i've been using for months as malware. (which i don't believe at all). I also checked and my drivers are up to date, there is no windows update to be done and from what I see there's no weird / suspicious background programs running.
Here are my specs :
Processor 12th Gen Intel(R) Core(TM) i7-12700KF 3.60 GHz
Installed RAM 32.0 GB (31.9 GB usable)
System type 64-bit operating system, x64-based processor
GPU NVIDIA GeForce RTX 3080 Ti
Here are my specs :
