Help System freezing for no reason.
GpuYankee
21
Hello, I have a serious problem with my pc for the past 6 months, I just don't know what is causing this. So the symptoms I saw were After my Gts450 ( which I bougth in summer) worked like a charm no freezing nothing when the probl started after a power-loss, I was outraged, my Mobo is Rampage Formula which has been updated to version 1001, i have got a q9300 but I didn't put it in yet, ram are okay swapped them put my ram sticks two same sticks in Left 2 channels and other two sticks in right channels they are 5-5-5-18 so thats 1gb in each slot ram names are Corsair Dominator, and Kingston Hyper-x. HDD Is good too its a WD 2tb Green edition. PSU Kimpro 550w ( thinking of changing it) everything seems good , sometimes the Mobo freezes inside the bios, I get a beep so that the system has attempted a good POST. I just don't know i have to use my old HD 3850 which wasn't freezing until today i tried swapping the cards GTS failed and know the ATi card has problems it happened, but there was time when it worked like a charm, Please help me i'm trapped in this mess
I doubt it. I would assume that 2 GPUs did not magically fail, unless the gpu devil lives in your house somewhere. Might want to pray the the GPU god, who is very powerful and has been known to make things work. (I did this when I built my own PSU cables for my GPU).
I could see the GPU issue being caused by the PSU. Because the MOBO problem seems to have happened after a hardware swap/power loss, I would guess MOBO. That could explain the freeing in the BIOS.
