Question Help to overclock FX 6100
Sep 7, 2019
46
I got a AMD FX 6100 and im planing to overclock it, so... My motherboard is a Gigabyte 990FX UD3, and i dont really know how to use the BIOS from it.
Can somebody help me with that?
With values and things that i need to Change there? I tried before with a 6300 and it didnt worked.
I hope that somebody can tell me how to mess with That weird BIOS.
BIOS is as simple as it could be. To OC that FX you just need to set multiplier higher than stock boost clock of 3.9 (CPU Clock Ratio) and change appropriate CPU voltage (System voltage control).
Hope you have a good CPU cooler or won't get far.
Reactions: GHASTECHEN
Sep 7, 2019
46
I got a watercooler
