Question Help to reformat hard disk ibm from 528 to 512
Jun 28, 2022
7
I have problem for hdd put up from eBay store I tried to reformat scotor size from 528 to 512 because need use this hdd in normal server please can you send me frimware to return Seagate because can't reformat this is part number for hard disk XS7680SE70113
IBM FRU: 01ML224 this is for IBM
You don't need to reflash the firmware, you just need to perform what's called a low-level format. This is different than a standard formatting that you see elsewhere.
IBM-SSG
IBM-SSGSSH51P9
E1A2
peripheral_type: disk [exe]
PROTECT=©
Unit serial number: HLK04EEJ0000822150Z3
LU name: 5000c500a181e568
mode sense (10) cdb: [5a 00 01 00 0e ee de ee fc ee]
lode Sense (block descriptor) data, prior to changes:
Number of blocks-3637089792 [exd8c99600]
Block size=528 [0x210]
mode select (10) cdb: [55 11 00 ee e0 de ee 0e 1C 00]
node select (10):
ixed format, current; Sense key: Illegal Request
Idditional sense: Invalid field in parameter list
Field replaceable unit code: 17
Sense Key Specific: Error in Data parameters: byte 13 bit 7
ry MODE SELECT again with SP=@ this time
mode select (10) cdb: [55 10 00 Ge ee ea Be Be 1c ee]
ode select (10) :
ODE SELECT command: Illegal request, type: sense key, apart from Invalid opcode
IBM-SSG
IBM-SSGSSH51P9
E1A2
PROTECT=©
node select (10):
ode select (10) :
This is problem i found with I try sg-utils
