Hi all, been getting BSODs once or twice a week on my build for the last few months. Last week I upgraded my CPU cooler and cleaned out the PC and have been getting the BSODs more frequently, about once a day. And the temperature is down from 50-80C to 30-60C instead, which confuses me!
The BSOD can happen during gaming, or closing a Microsoft Word file, or it seems at any time almost. All the errors are different, from IRQL NOT LESS OR EQUAL, to MEMORY MANAGEMENT, to KERNEL FAILURE (or something).
I ran a Prime95 test and it passed the Small FFTs, but failed the Large FFTs with a "Rounding error". So I'm thinking it may be the memory. What's weird is that it always fails on one worker within 2-3 minutes, but then the test runs perfectly fine for the next hour or more. A couple times the crash even resulted in a no POST and I had to reseat the CMOS battery to get to the bios.
Down-clocking the memory from 3200mhz to 3133mhz (timings same) seems to reduce the issue of Prime95 rounding error. However, I still got crashes/BSODs.
I also re-installed windows and all the drivers, including running DDU and reinstalling graphics drivers from AMD. No luck.
Today I've down-clocked all the way to 2133mhz (same settings as if XMP was never enabled), andno crashes for a while just crashed while editing this post 🙁
It SEEMS like a memory problem to me, but before I get it RMAed, wondering if you guys could help shed light into the problem more. Could voltages be the cause, and if so which voltages should I increase? Could it be the motherboard DIMM slots, how would I test that if my motherboard manual specifically states to slot in RAM in a certain order/slots? Is it most definitely not a CPU issue?
How do I 100% confirm its the RAM so I don't RMA it and still have the issues?
Appreciate any help. PC Specs below.
Cheers,
Pin
MSI X570 Gaming Plus
AMD Ryzen 5 3600X - no overclock
2x 8GB Corsair Vengeance LPX DDR4 3200mhz
Sapphire Pulse Radeon 5700XT
EVGA Supernova G3 550
Windows 10 Pro
RAM Timings
16-20-20-20-38
Voltage Settings:
MEM VDDIO 1.35v
MEM VTT Auto
VDDCR SOC 1.1v
CLDO VDDP 0.9v
CLDO VDDG 1.1v
All other motherboard settings on auto (no PBO)
Cheers,
Pin
Windows 10 Pro
RAM Timings
16-20-20-20-38
Voltage Settings:
MEM VDDIO 1.35v
MEM VTT Auto
VDDCR SOC 1.1v
CLDO VDDP 0.9v
CLDO VDDG 1.1v
