[SOLVED] Help troubleshooting Daily BSOD
Colif
Win 10 Master
summary:
Passes prime 95
Passes Memtest
Voltages look about normal in hwinfo
Storage drives seem ok I(ran magician)
You already said you had a Blue Yeti before I asked (slaps self)
specs:
MSI X570 Gaming Plus
AMD Ryzen 5 3600X - no overclock
2x 8GB Corsair Vengeance LPX DDR4 3200mhz
Sapphire Pulse Radeon 5700XT
EVGA Supernova G3 550
Any BSOD since you put in new LAN card?
Nov 13, 2021
44
No BSODs for two days.
Since the new LAN card (disabled the on-board port via device manager), only change I made was unplugging secondary SSD drive.
Fingers crossed...
If anything BSOD frequency has reduced to a usable PC state, which is good.
gardenman
Hopefully that works. Here's the result for latest dump in case it's needed: https://jsfiddle.net/njbo7arm/show This link is for anyone wanting to help. You do not have to view it. It is safe to "run the fiddle" as the page asks.
File information:112821-10187-01.dmp (Nov 28 2021 - 07:22:10)
Bugcheck:KERNEL_AUTO_BOOST_LOCK_ACQUISITION_WITH_RAISED_IRQL (192)
Driver warnings:*** WARNING: Unable to verify timestamp for WdFilter.sys
Probably caused by:memory_corruption (Process: MoUsoCoreWorke)
Uptime:0 Day(s), 8 Hour(s), 36 Min(s), and 39 Sec(s)
[/spoiler]
This information can be used by others to help you. Someone else will post with more information. Please wait for additional answers. Good luck.
Nov 13, 2021
44
wdfilter.sys is windows defender mini filter... lan again.
Brand new PC incoming?
New motherboard and CPU already setup:
MSI Mag B550M Mortar WIFI
Ryzen 5600X
Didn't even need to reinstall windows.
You know I'm thinking there is a possiblity that the wintun.sys driver connected to Astrill VPN may be the culprit. Am staying away from it for the next week while testing the CPU/mobo replacement, but will re-test it again afterwards.
44
Full week of PC use and no BSOD. Looks like my problem is solved.
Will return motherboard and CPU for maintenance and see what they say. Will report back if I get a clear answer on the cause.
Thank you Colif for your help.
Reactions: Colif
Nov 13, 2021
44
Just as a final update to this thread. My seller got back to me and it looks like AMD will be giving me a brand new 3600X. Unfortunately AMD did not tell my seller what the problem was, only that it would be replaced with a new one.
So it was the CPU.
