Build Advice Help troubleshooting
Mar 9, 2024
8
Hello,
I am currently (trying) building this; https://pcpartpicker.com/list/w3kNYd
EDIT: i chose the wrong motherboard, this is the right one: https://pcpartpicker.com/list/rP6HqH
I have completed the motherboard build with the Gpu, Cpu, Ram and cpu cooler and trying to boot it up to Bios atleast. But I am getting no video for my screen, I am connected to the gpu with hdmi.
The motherboard LED debug is currently lighting up both red and orange.... any help? All fans are running smooth and the gpu rgb is active
According to your motherboard manual, that indicates an issue with the CPU and/or RAM. Perhaps try booting with one RAM stick and trying different slots on the motherboard to rule out faulty RAM and/or a dead memory channel. Also check that you have the CPU power connector plugged in as well.
Is it possible to connect a motherboard speaker? It may help to give a better idea as to what specifically has gone wrong.
I also noticed that your PCPartpicker list states that the motherboard may need a BIOS update for the 7800X3D. If the above steps don't work, you may want to follow the steps under "Updating BIOS with Flash BIOS Button" in your motherboard manual.
Remove the GPU and use the motherboard HDMI to see if you can get a display
I would also try this as well before doing the BIOS update.
