Hi, I was compelled to look into my tower's CPU temp when my performance playing a CPU/GPU-demanding game suddenly plummeted yesterday (frame rates from ~50 to ~5, including in menus).
I shut down the game and—thinking I might be experiencing either CPU/GPU throttling—ran a couple diagnostic programs I had on hand: SpeedFan and Speccy. Both told me my CPU was running to nearly 90C, as I recall. When I let the computer idle, the CPU temp dropped to ~60C, where it's remained for the last day as I just do low-CPU-demand tasks.
As the fans all seemed to be functioning normally, I redid the thermal paste, but that hasn't affected the idle temp at all. So I'm looking for other ideas, and after doing some reading have a few questions I hope someone could help me with.
Here's some basic specs, first: it's a 2-year-old tower. AMD Ryzen 7 1800x CPU. Since purchasing the computer I've replaced two parts: added a M.2 SSD that sits just below the CPU on the motherboard, and upgraded my GPU to an NVIDIA GeForce RTX 2060, which sits a little further below the CPU and runs quite a bit hotter than my original graphics card.
- Is it likely that the high CPU idle temps are being caused by the heat generated by these two added items? (the GPU seems to idle at around 40C; I can't get a temp reading from the SSD but it's quite warm to the touch).
- I've read a little about different ways CPUs report temps. Running NWiFO64, I see that while my CPU (Tctl) reads 60C, the CPU (Tdie) reads 37C. Is it maybe the case that my CPU isn't in fact running hotter than it should be? If so, is it possible that the CPU might be throttling itself unnecessarily in-game?
