Suppose I'll start by saying that I'm just now jumping on board PC gaming and have come to hear about various sync technologies, which I feel I have a flimsy grasp on, which gets a little trickier to feel confident about when various people on all sides have such strong and divisive opinions on them. From what I can gather, v-sync is primarily meant to eliminate screen tearing and maybe provide a more stable framerate, but with input lag being the main compromise due to the GPU and monitor struggling to keep up or remain "in sync," if you will. To that end, g-sync sounds like an answer to said input lag since from what I've read, g-sync monitors can freely vary their refresh rate to better match the GPU. Please correct me if I have this or anything else wrong.
Now I've also heard that if you turn off v-sync and limit your game's framerate to 60 FPS you'll reap the benefits of a smoother overall experience, but have yet to test it myself. Just based on first impressions (and as a primarily single player gamer), v-sync seems more appealing since it simplifies things and really helps with screen tearing. For reference, Witcher 3 was the first game I tried with my recently assembled PC (settings maxed out) and if I turned v-sync off, the screen tearing was more than just a bit noticeable, so the effective elimination of it with v-sync makes it (and g-sync, by extension) more appealing.
Now I've been using my HDTV as a stand-in for an actual computer monitor (I know some will raise their pitchforks at this idea, but again, it's a placeholder), which has refresh rate of 60 hz. To that end I suppose one question I have is if buying a monitor that simply has a higher refresh rate will help alleviate my current screen tearing predicament with v-sync turned off, since it is quite distracting? Or would going for a g-sync monitor be a potentially worthwhile avenue (I found one for $400, and I figure I'll wait till the holidays in case there's a sale)? Here are my system specs if it helps at all:
i5-7600k (OC'd to 4.5 ghz)
GTX 1060 6GB OCV1
8 GB RAM DDR4 @ 2400 (getting another 8 GB stick will likely be my next upgrade)
Thank you to anyone who answers!
GTX 1060 6GB OCV1
