Question Help undervolting Ryzen 7 5700x3d
chriswa2002
203
6
18,695
Hi everyone, I recently bought and installed a ryzen 7 5700X3D in my computer, before it I had a ryzen 5 4600g. Before upgrading the cpu, temps would be around 40~ idle and around 65~ in games, now with the 5700x3d it idles at around 53-60 and when in games it reaches 80~, and these temperatures make me a little uncomfortable.
Many undervolting videos have appeared on my youtube but im scared to change voltage because I don't want to mess something up and make my pc not boot or damage the cpu, most I have done in BIOS is enabling XMP. Some people change settings in their BIOS and some use a program called PBO2 Tuner.
I also tried changing the core curve values to -30 using PBO2 Tuner but it didn't seem to do much.
(Screenshot of the mobo control center)
https://prnt.sc/5oaRlpp61PHc
I saw in some videos that people change the "VCore" values to -0.05 and -0.1, is that the setting that makes temps go lower??
Im new with undervolting/overclocking sorry if this is dumb.
Many thanks in advance for the help.
Be careful with x3D chips, they don't react same. Lowering voltages does lower temps too but too much can lead to instability and/or lower performance. 3D cache is more sensitive than "normal" cache.
Which cooler do you have? Upgrading cooler can do more good than any undervolt.
Reactions: Phaaze88
Hello,
I’ve been undervolting my 5700X3D using PBO Tuner, setting all cores to -30 since a -50 offset doesn't offer much benefit. This adjustment results in approximately a 10-degree temperature reduction and a 15W decrease in power consumption during multicore tasks. Interestingly, it reduces the voltage from 1.2V to around 1.14V under load, as indicated by OCCT. Additionally, I noticed that if I put my PC into sleep mode, wake it up, and apply the negative offset again, the voltage further drops to 1.09 - 1.1V. This leads to a power reduction of 20-25W and a temperature drop of 13 degrees Celsius.
In games, it doesn’t go higher than 75 degrees. Previously, I had a Ryzen 2400G, and after upgrading I also thought the idle temperatures were high. It draws around 30-40W at idle, and the temperatures are 40-50 degrees while surfing the net. Most of that draw comes from very high default SOC voltage which I changed from 1.2V to 1.1V. I don't think it made much difference. It's worth noting that my PC case isn't the best when it comes to cooling and airflow, which might contribute to some of the temperature readings.
Could this indicate an issue with your testing methodology? Do you conduct multicore testing, and for how long? Don't you see any difference in before/after results?
As cpu cooler i have an amd wraith prism
Hello,
Well i did some vague testing, i set the curves to -30, let windows be idle for a bit, surfed the web, then started playing some games, i didn't do intensive testing.
Wraith is not recommended for 5700X3D, go for an aftermarket one. I personally am using the ThermalRight PA 120 SE, it is a bit of an overkill, but I live in a place that temps are higher. I also have 6 fans to get some airflow going from front to back that needs some extra work to get to a sweet spot.
My temps are usually between 42-56º at tops during some heavily modified gaming(Stalker GAMMA and Witcher 3).
Also I suggest not doing any clock or voltage work on yours, these CPUs are not meant to be overclocked or undervolted, all I hear is complaints everywhere from people who did it and regret it for not being able to go back unless with some heavy BIOS work.
Also what the last reply said, try a good 12,3 W/mK, spread it evenly instead of a blob. Good luck!
i would upgrade your cpu cooler.
what are your full specs.
and pc case.
