Hi there !!
watch the video please...you'll hear what I'm talking about ! Can't find anything in the mobo manual....really don't know what it's all about.
https://www.youtube.com/watch?v=5kWHQ9Gk-NY
Beep sequence at the beginning..... Then I show some BIOS options ... If you see anything unusual in my BIOS options, please tell me ! Thanks !
boot sequence here:
https://www.youtube.com/watch?v=gDPvUJfxtc0
Config : C7H170-M Supermicro mobo / 4x4Gb HyperX Kingston DDR4 2133mhz memory modules / booting from M2 intel 600p SSD. Have a LG DVDRW and Seagate 3Tb Hd connected as well... Using built-in Intel HD Graphics 610
Linux works fine .. In fact never had such a good linux experience ! just don't know what are those f$^& beeps...using Fedora25 with latest 4.10 kernel.
Here is the config as seen from Linux inxi command :
System: Host: localhost.localdomain Kernel: 4.10.10-200.fc25.x86_64 x86_64 (64 bit)
Desktop: Cinnamon 3.2.8 Distro: Fedora release 25 (Twenty Five)
Machine: Device: server System: Supermicro product: C7H170-M v: 0123456789
Mobo: Supermicro model: C7H170-M v: 1.01
UEFI [Legacy]: American Megatrends v: 2.0 date: 12/19/2016
CPU: Dual core Intel Pentium G4560 (-HT-MCP-) cache: 3072 KB
clock speeds: max: 3500 MHz 1: 800 MHz 2: 799 MHz 3: 800 MHz
4: 800 MHz
Graphics: Card: Intel HD Graphics 610
Display Server: N/A drivers: modesetting,intel (unloaded: fbdev,vesa)
Resolution: 80x24
Audio: Card-1 USB Audio CODEC driver: USB-Audio
Card-2 Texas Instruments PCM2902 Audio Codec driver: USB Audio
Sound: ALSA v: k4.10.10-200.fc25.x86_64
Network: Card: Intel Ethernet Connection (2) I219-V driver: e1000e
IF: eno1 state: up speed: 1000 Mbps duplex: full
mac: 0b:c2:7a:e1:d6:39
Drives: HDD Total Size: 3000.6GB (0.4% used)
ID-1: /dev/sda model: ST3000DM008 size: 3000.6GB
ID-2: /dev/nvme0n1 model: N/A size: 128.0GB
Partition: ID-1: / size: 49G used: 4.4G (10%) fs: ext4 dev: /dev/dm-0
ID-2: /boot size: 976M used: 119M (14%) fs: ext4 dev: /dev/nvme0n1p1
ID-3: /home size: 60G used: 301M (1%) fs: ext4 dev: /dev/dm-2
ID-4: swap-1 size: 8.43GB used: 0.00GB (0%) fs: swap dev: /dev/dm-1
RAID: No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors: System Temperatures: cpu: 29.8C mobo: 29.5C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 208 Uptime: 24 min Memory: 1315.0/15944.2MB
Init: systemd runlevel: 5 Client: Shell (bash) inxi: 2.3.8
boot sequence here:
4: 800 MHz
Resolution: 80x24
