I recently upgraded my monitor, knowing that I would also need to upgrade my graphics card. Now I'm trying to determine both which GPU to get, but also if I need to upgrade anything else (ie, power supply, fans, etc). I briefly tested the monitor with my current GPU and it was (I think) overheating and shutting down my whole PC, so I'm conscious of getting too hot.
Monitor:
APPROXIMATE PURCHASE DATE: Flexible BUDGET RANGE: Flexible, but hoping for <$700 After Rebates
USAGE FROM MOST TO LEAST IMPORTANT: Gaming. Baldur's Gate 3 and Cyberpunk 2099 are the most taxing games I'm playing in the near future. I also use it for remote work, but not graphically demanding work.
CURRENT GPU AND POWER SUPPLY: AMD Radeon RX 5600 XT - 6GB (VR-Ready). 600 Watt - High Power - 80 PLUS Gold Certified - FREE Upgrade to 600 Watt - Thermaltake Smart Series - 80 PLUS Gold (That seems a bit like gibberish, but that's the description from the specs when I bought the PC).
OTHER RELEVANT SYSTEM SPECS:
Case: iBUYPOWER Slate 4 Tempered Glass ARGB Gaming Case
Processor: AMD Ryzen 5 3600 Processor (6X 3.6GHz/32MB L3 Cache)
Motherboard: GIGABYTE B550 GAMING X - ARGB Header (2), USB 3.2 Ports (4 Type-A), M.2 Slot (2)
Memory: 16 GB [8 GB X2] DDR4-3000 Memory Module - Certified Major Brand Gaming Memory [Free Upgrade to 16GB DDR4-3200 XPG D41 RGB]
Video Card: AMD Radeon RX 5600 XT - 6GB (VR-Ready)
Power Supply: 600 Watt - High Power - 80 PLUS Gold Certified - FREE Upgrade to 600 Watt - Thermaltake Smart Series - 80 PLUS Gold
Processor Cooling: iBUYPOWER 120mm Addressable RGB Liquid Cooling System - Black
Primary Storage: 500GB WD Blue SN550 M.2 PCIe NVMe SSD -- Read: 2400MB/s; Write: 1750MB/s
Case Fans: Default Case Fan
PREFERRED WEBSITE(S) FOR PARTS: No preference. I'm familiar with newegg.com and ibuypower.com. COUNTRY OF ORIGIN: United States
If you do not know of a store for your country this thread will point you in the right direction: http://www.tomshardware.com/forum/id-1643019/guide-international-users-links-part-stores.html
PARTS PREFERENCES: none
OVERCLOCKING: No SLI OR CROSSFIRE: No
MONITOR RESOLUTION: 3440x1440
ADDITIONAL COMMENTS: I'm not really interested in fiddling with the system to get the best possible performance. I'm primarily interested in plugging in and playing. If I can do so with high graphic settings, that's great, but I'm not too concerned with FPS. (though that's maybe because I don't know what I'm missing
Monitor:
Dell Curved Gaming, 34 Inch Curved Monitor with 144Hz Refresh Rate, WQHD (3440 x 1440) Display, Black - S3422DWG
