Help upgrading mobo and cpu.
hillelslovak
147
http://
That is my system above. All I have changed is put an 8gb ddr3 ram stick, a 600w psu, switched out stock hdd and put in 2 toshiba 3tb hdds, and an amd r9 380x 4gb gpu.
It has become time to upgrade my cpu and motherboard. I want to switch my processor from my amd fx 6200 to intel, as I am seeing intel cpus whooping amd ones.
So, I have a budget of 300-350 US at the most. I dont really want to have to upgrade all my ram sticks, and I think i5 processors utilize ddr3 mobos, right?
So, what i5 or i7 and a matching mobo could would you guys recommend within my range?
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor ($239.99 @ SuperBiiz)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler ($35.00)
Motherboard: ASRock ASRock H97 Anniversary ATX LGA1150 Motherboard ($61.98 @ Newegg)
Total: $336.97
Generated by PCPartPicker 2016-05-28 17:39 EDT-0400
- buy the h7 from newegg.
- the only major difference between the i5 and i7 is hyper threading, which is better for live streaming/recording +lower render times, gaming wise close to zero difference or zero.
- the xeon is an i7 4790 , without the ocing feature and...
Total: $336.97
- the xeon is an i7 4790 , without the ocing feature and onboard graphics(you use your Gpu graphics anyways).
-what psu do u have otherwise ur pc might not last a year.
