Help Upgrading My PC
Ksbland09
I built my first PC about two years ago and I feel its time for an upgrade. I want a budget Workstation/Gaming rig that will close to Max out all the upcoming next generation titles at 1080p with good fps. I also want to use it for and decent amount of Photoshop, Adobe Flash, and some light video rendering. I'm also plan to use a Cintiq soon if that helps. I'm really want to switch out components rather than gutting and replacing everything. I'm willing to overclock or whatever you guys suggest I do. Thanks!
My Current Build.....
CPU: FX 6300 (Stock Cooler)
Motherboard: GA 78lmt usb3
Ram: Gskill Ripjaws 8gb (2 x 4gb)
PSU: Corsair CX600
HDD: Seagate Barracuda 500gb 7200rpm
GPU: Gigabyte HD 7850 1gb
Case: Corsair 350D
I'm very sorry. This is only my second post. I typed it in the wrong text box I guess. Anyway, I built my first PC about two years ago and I feel its time for an upgrade. I want a budget Workstation/Gaming rig that will close to Max out all the upcoming next generation titles at 1080p with good fps. I also want to use it for and decent amount of Photoshop, Adobe Flash, and some light video rendering. I'm also plan to use a Cintiq soon if that helps. I'm really want to switch out components rather than gutting and replacing everything. I'm willing to overclock or whatever you guys suggest I do. Thanks!
Latest posts
