Help upgrading PC
andsotelo
Commendable
Aug 18, 2016
Hi i currently have a T3500 Dell Workstation, I plan on just building a brand new PC but was wondering what should obviously be scavenge able.
It's case, I assume I just just strip it of everything except the power supply (525w) however I don't know if my PSU is good enough for the new pieces I plan on buying.
Tomorrow i'm buying my friends AMD R9 290 for $150 CAD (Club SD)
I plan on getting either one of the faster i5's or lower i7s and am looking for DDR4 ram compatible motherboard.
I'm obviously going to buy everything else inbetween but wonder if there's any advice that you can give me to upgrade my computer into a gaming computer.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor ($276.89 @ Amazon Canada)
CPU Cooler: Cooler Master Hyper T2 54.8 CFM Sleeve Bearing CPU Cooler ($14.99 @ NCIX)
Motherboard: ASRock Z170 Pro4S ATX LGA1151 Motherboard ($110.00 @ Vuugo)
Memory: Team Dark 16GB (2 x 8GB) DDR4-3000 Memory ($74.99 @ Newegg Canada)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive ($49.99 @ Memory Express)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($62.75 @ Vuugo)
Case: NZXT Source 210 (Black) ATX Mid Tower Case ($49.99 @ Newegg Canada)
Power Supply: EVGA SuperNOVA P2 750W 80+ Platinum Certified Fully-Modular ATX Power Supply ($142.99 @ NCIX)
Optical Drive: Asus DRW-24F1ST DVD/CD Writer ($7.20 @ Amazon Canada)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($113.98 @ DirectCanada)
Total: $903.77
Generated by PCPartPicker 2016-08-18 16:54 EDT-0400
Here is a good starting build if you need to save more money lower the RAM to 2x4GB and get a slightly worse PSU although I always try and go overkill on that considering I've had one kill a some GPU's.
Hey I appreciate your help,
What graphics card do you recommend, I plan on making the switch to PC gaming and don't plan on upgrading for at least a year. I don't know if I want my friends R9 290 because it seems to not run very well with todays games.
BUDGET: i'd like to stay around 900-1200 CAD, i suggest paying well for GPU,CPU,Motherboard, and Ram and maybe going a bit cheaper with things like a case, memory, and I don't need a stoage because I had a 1TB hardrive with windows installed that i plan on just transfering over
Go with the system I have set but remove the 1TB HDD, keep the SSD though for windows and some games. Don't cheap out on a case as a half decent one only costs $50, save $20 and get a pile of rubbish really?
I'd probably buy the R9 290 used if it has been looked after and has a good cooler considering how much value for money they are.
