Hi ya
I'm looking to update my gaming PC to play at a 3840 X 2160 resolution. I figure I have to upgrade my GPU and monitor. Then double my ram. But I'd rather not update my motherboard right now. Wondering what upgrades I can make to my rig without ripping the mobo out. I am open to upgrading the processor if there is something worth updating now with an 1150 socket.
System Specs
CPU: I5-4670K
MOBO: Z87 Pro ATX 1150 socket
RAM 8 GB DDR3
GPU: GTX 770 4 GB
I can spend a good amount upgrading. If you think it's time to move on from the 1150 I would appreciate your advice.
Looking to spend around $1700
System Specs
CPU: I5-4670K
RAM 8 GB DDR3
GPU: GTX 770 4 GB
