hey guys. First time posting on here. I have an Ibuypower Trace 930 prebuilt. It has been fine for my needs until now but I recently bought an oculus rift s and was disappointed in the performance. I just bought a used EVGA 1080 ti FTW3 on eBay to upgrade the gpu but was wondering if you guys think my cpu is the problem. Please see below my specs for the prebuilt:
Motherboard - ASUS H110 Plus
RAM - ADATA XPG 288 Pin DDR4 2400
GPU - MSI GTX 1060 3GB
CPU - Intel i7-7700 3.6Ghz
CPU Cooler - AVC 80mm
Case Fans - AVC 120mm
Power Supply - Allied 500W Non Modular
SSD - ADATA SU600 120GB HDD - Western Digital Blue 1TB 7200 RPM
I know I’m going to need to update the power supply to use the 1080ti but would you guys also upgrade the motherboard & cpu? I’m new to all of this and any help is greatly appreciated. I know it would be easier to build from scratch but I would like to use as many components as possible from my prebuilt. Any help is appreciated
