a friends computer has a worm which HijackThis picked up , but we cant delete it because it hides the main virus folder from view.
( wuamdrg.exe is one of the extensions )
I deleted 15 other virus files using HijackThis , but the system reinfects itself after every scan.
The folder C:Windows/system32/wuamdrg.exe shows up in Hijackthis scan , but can not be found on the C. drive ( not visible ) , so i cant delete it.
what is the best tool to delete this worm ?
got urgent work to finish a major work assignment.
thankyou kindly for any help
