Question HELP URGENT! my external drive swapped from E to H and now i cant use it
Aug 20, 2023
28
recently my usb ports got messed up so now that i fixed them i start up my pc and everything is normal, well my WD passport 4tb external harddrive that i use to store all my stuff on appears as drive H instead of E and now i can't launch any of my apps on it. when i click on them they say "please insert a disc into usb drive (E:)"
PLEASE HELP!
Please show us a screencap of your Disk Management window.
Likely, you can just change the drive letter from what it is now, to E.
i tried that but E isnt available cuz it shows that e was previously used but isnt available anymore as if its a dif drive and ill send it, but it might take a minute cuz im not sure how to use imgur
It is hard to tell whats going on with all the jumping around in the video.
Is the drive currently labeled H, what used to be the E?
What drives or devices are currently connected to this system?
This includes any and all adapters, with or without drives connected.
yes H used to be E.
and i have my mouse, keyboard, and the WD passport.
do u need to know like everything else connected that appears in the device managers?
