HELP, URGENT
longabletv
66
I connected everything up to do an external build. Attempted to use the screwdriver on the PW to boot it up. And BANG, the power supply makes a noise and starts to smell.
Have I literally just fucked everything up? I'm freaking out...
what power supply did you buy? you may have not damaged that other parts but if you got a faulty psu than you may be able to RMA through the place you bought it.
I would definitely return that power supply. Leave out the part about using a screw driver to boot and get a new one.
Sorry for the language guys, I was just freaking out..
I took all parts to the local PC shop, he tested and all parts are fine. It was just a bad PSU. This is my first build and to be the unlucky one, well it was quite a shock; thanks for the replies guys!
